ARRMA TYPHON FRONT BODYPOST
Made of 7075 aluminum, then red anodized.
Replaces the front plastic check holder.
Delivery : 1x Bodypost.
ARRMA DIFFMOUNT V4
Made of 7075 aluminum, milled from the full.
Increased stability against the plastic part.
Plug & Play
Suitable for: V4 Motor mount
Weight: 11.6g
Delivery : 1x Diffmount, 2 screws.
ARRMA ACKERMAN PLATE
Ackerman plate made of 3mm 7075 T6 aluminum.
Fits: V1, V2, V3 (2018) and V4 (2019) models, Limitless, Infraction.
Weight: 7,4g
Delivery: 1x Ackerman plate
ARRMA REAR SKIDPLATE BUMPER COMBO
Skidplate made of 7075-T6 aluminum.
POS Bumper in the usual quality.
Now it is finally possible to use a bumper and a skidplate without losing ground clearance unnecessarily. The bumper is mounted under the skidplate.
Fits: Talion, Typhon, Kraton, Outcast, Senton, Kraton V1-V4.
please Note:
There are 2 additional holes (Ø 4-4,2mm) to be drilled in the chassis !!
Scope of supply : 1x Skidplate, 6 screws for the base plate, 2 nuts. 1x Bumper
Wingmount Arrma Kraton / Outcast
Sturdy, multi-piece wing mount suitable for Arrma Kraton, Outcast / Notorius, and Talion
Does not fit the Talion model 2018!
Does not fit on the Typhon!
This Wingmount, made of the same material as our Bumper, is double-layered and is additionally stabilized by the screw connection on the damper bridge.
Incl. All (additional) required screws and spacers.
Bumper Arrma Kraton V3 / V4 front
Stable front bumper suitable for Arrma Kraton V3 and V4
Incl. longer (M4x14) screws for mounting.
Incl. Hingepin counterholder. This ensures, instead of the original mini dumpers, to keep the wishbone pins in the front in position. The original bumper must be dismantled! Screws for mounting are of course included.
Bumper Arrma Outcast Front
Stable, supported front bumper suitable for Arrma Outcast
V1, V2, V3 and V4
Incl. longer (M4x14) screws for mounting to the chassis, and all screws for mounting.
Of course, this bumper also fits perfectly on the Arrma Kraton (you may need to adjust the front of the car slightly)
The peculiarity of this bumper lies in the support, which largely prevents a compression of the body.
Frontbumper Arrma Kraton / Outcast 4S
Stable front bumper for the new Arrma Kraton 4S, and the Outcast 4S also any of the 3s range
Incl. Counterholder for the wishbone pins and all additional screws for attachment.
ARRMA DIFFMOUNT V4
Plug & Play
Weight: 11.6g
Weight: 7,4g
please Note:
V1, V2, V3 and V4
