Typhon Poseidon gearing
Dazer
So i decided to purchase a Mamba X and a Poseidon 2200kv motor. I was just wondering what's the highest pinion gear you guys would recommend for mostly bashing with a bit of drag racing? I don't want to run to hot but I want it to be fairly quick on and off road. Is there a fan you guys would recommend that might keeep temps slightly lower? Also I guess I should state I'm running nothing but 4s. I don't know if it's relevant or not but I'm running avid bearings as well.
jonUF02
Orlando, FL
  2. Nero
  3. Outcast 6s
  4. Outcast 4s
I'd say somewhere in the 16 to 19 range on 4s, you'll just have to experiment and check motor temps.
