JoshHefnerX
After viewing the thread:
https://arrmaforum.com/threads/digging-deeper-into-the-rocker-posts-rod-ends-shock-shafts.2035/
I decided to take a look at that interference when my Nero finally came in.
I found some small washers out in the garage and decided to space up the shock cups.
It moved the cups up 7.2mm so I threaded the spring collars up 7.2mm to make up the difference.
I found that when cycling the suspension that the droop would now bottom out on a the skid plate, whereas they were stopping on the droop at the point of interference. So you gain an overall droop of 3/4" roughly. Didn't get any pics of that.
On an aside, one of the shock ends started pulling some of the threads out of the end before I'd even run it...
On the compression side, it still compresses just enough to barely smack the skidplate on the ground.
How does it run? I didn't notice any ill effects when driving it around or jumping. I can't say for sure this would cure the broken rod ends but it does get rid of the binding point mentioned by @Havoc
I did however still did manage to snap 2 rod ends - after hitting a steel pole when landing.. Not the trucks fault though... DOH
