ptr1ck
- Granite
My bench grinder gets all sorts of use.It was grind metal or grind plastic. I chose the plastic ?
From what I saw on mine, the plastic balls wear down to the point that the tie rods fall down away from the center of the ball. The rod end sitting around the smaller section of the ball causes a lot of slop. Putting the short pieces of silicone tubing in keep the rod ends at the center of the ball, eliminating the extra slop from wear. Trust me and just try it for the tie rods. Just 8 little pieces of tube.
For me the center of the balls are certainly worn down. They are liable to be a softer composite intended to be a wear item. Replacing the balls with metal is going to make the rod end the wear item. I intend to keep the balls as the wear item, but alleviate the slop that seems to come on prematurely by using the silicone bushings.
I think Traxxas makes 3 different thicknesses for the pivot balls, so should be able to find a thinner one. I’ll try to post a pic of the 3 different sizes I have.
Can you try them and see what fits?
