Negative. If I get the v1 finished tonight along with if the rain can hold off until I'm done at work tomorrow morning.You try it yet?
Daaaaaaang didnt know they could go that tight!!
Very original paint job lol!View attachment 252819In all fairness the Limitless here is not mine, the photo is mine tho!
I SEE you rocking the futaba!!!Very mineView attachment 252824
One day you will understand tight-er the better. But for now let's leave it as yeah. You can crank em down pretty tight. Second set of springs are from @RedondoBeachRC. Witch I haven't tested. But made some adjustments to em. Since I found them to be too soft in the beginning. "Could have been my imagination" I heat them up a few different ways. After the 5 heat cycle. I decided to hardened them there's absolutely no give.Daaaaaaang didnt know they could go that tight!!
Yea they look like they could handle a 1.1 Mazda3.One day you will understand tight-er the better. But for now let's leave it as yeah. You can crank em down pretty tight. Second set of springs are from @RedondoBeachRC. Witch I haven't tested. But made some adjustments to em. Since I found them to be too soft in the beginning. "Could have been my imagination" I heat them up a few different ways. After the 5 heat cycle. I decided to hardened them there's absolutely no give.
I miss my zoom zoomYea they look like they could handle a 1.1 Mazda3.
Sorry man I should have known.I miss my zoom zoom
Discount on the new onesNot your imagination.. went over it with the engineer and the 60lb force is at 1” on depth compression. But that spring doesn’t compress 1”.. so it seeing about 39-42lb of force in its effective range, still more than stock but not a ton more.
I have a redesigned version that should be significantly much more stiffer and it should be arriving soon.
Finally, 8s ready
35/36. Feel like if I'm going down, might as well be a blaze of gloryThat’s a monster pinion!!
