Maxx 6 with 1650, 40 tooth spool and 20 pinion
Oh, so you built a rocket? ?
Pretty much, going to get some bigger esc's to put in both carsOh, so you built a rocket? ?
Yo, what is that? Never seen one converted like that if that's actually a typhoon... You should share the parts list!
Yes,I talked to a guy at castle for a good 30 min yesterday and told him the problem I'm having with blowing the capacitors on the maxx 6,s and wanted to switch to castle. He was very informative and told me the new xl 8s would be perfect for my talion, but should put in the xlx for the typhon for speed.You should check out the new 8S Castle system. Seems like it will be awesome.
http://www.castlecreations.com/en/1-6th-scale/mamba-monster-x-8s-33-6v-esc-010-0165-00
Yes, it is a typhon.Yo, what is that? Never seen one converted like that if that's actually a typhoon... You should share the parts list!
what rim/tire combo is that?
If you have access to a 3D printer, I highly suggest you get the T-Bone fix file from @Camaroboy383 instead of using that useless aluminum plate. I really want to like the T-Bone bumper, as I own two of them, but they just don't hold up the way they made them. Hope you have better luck with yours.
Yep I have a SWB and LWB chassis plate too. Neither are being used. The little nut is hard to get lined up by the motor. Can’t pull the motor without taking off the skid plate. It’s a PITA. My bumpers both pulled the screws thru. Would take a much larger head to secure them now. I could use a wing button washer thing, but I’m afraid it would snag.Yea the bumpers are cheap but I guess they are replaceable easy enough, they look cool though. I also have the chassis plate, made cheap and the screw holes didn’t line up. I thought T bone was a better company. Live and learn.
I was thinking the same thing, that aluminum pos has to go, probably adds more stress than it worth. ThanksYa, as @jondilly1974 stated above that aluminum angle is bad news.. I would ditch it asap.. it can cause more harm than good... file I designed for the fix can be found on thingiverse...
Waiting on the cat pack, then I can try it.This is just to post pics of your stock or modified arma typhon for a little fun.
