The 20kg one is only copper and aluminium gears. Most people get the 23kg ones which are the metal gears and are faster.
Yeah, seen that vid and was definitely keeping away from the 23kg. I would really like to try one of these cheaper servo options so I don't have to worry about destroying it but i'm unsure about them putting up with what I dish out. Thinking I might suck it up and go get a savox sw1210sg but I don't want to run a more expensive servo until I get a better servo mount as I don't think anyone can say for sure if it's the weak ads15m servo or the weak kraton servo mount that cause premature failure.don't get the power hd23. I got it and it can barely fkn move the tires but for some reason the power hd 20 has more torque. A guy in youtube tested them and the 20 pulled higher numbers. I replaced my servo with a bluebird hb20b.
u might as well get the bluebird if yr spending that much. This poop moves planet earthYeah, seen that vid and was definitely keeping away from the 23kg. I would really like to try one of these cheaper servo options so I don't have to worry about destroying it but i'm unsure about them putting up with what I dish out. Thinking I might suck it up and go get a savox sw1210sg but I don't want to run a more expensive servo until I get a better servo mount as I don't think anyone can say for sure if it's the weak ads15m servo or the weak kraton servo mount that cause premature failure.
Who sells them?Yo
http://www.rcmart.com/blue-bird-bls...ss-digital-servo-p-67626.html?cPath=1099_1030Who sells them?
I bought a used talion that has one if these and its still going fine. So bought a few to use in other rcs and they do pretty darn good for the price. (Running 3 in total☺)
Bluebird BLS-H50B. Moves more than ur rcIn my experience of the 20kg it’s not up to the job on a Kraton. I was hoping it would be after the standard one went but it can’t pull it’s weight with a set of badlands on. Mines going for something better
Well I decided to order a super cheapy to see how it fairs. Got the JX PDI-6221mg on the way, not expecting much out of it but some say it's decent some say it's garbage, for $13USD I could care less as long as it doesn't take anything with it when/if it goes. Will then decide what I should get if needed. I prefer to buy from stores so if I have any problems I know where to go. If this cheapy takes a good beating and keeps ticking I may just look at an upgraded JX servo instead of going to the savox, or hitec that my buddy keeps telling me he loves.
Nice, yeh my shop has the 32kg version of those alloy case JX's and I was thinking that might be my next choice if this cheapy holds up ok.I've got this JX servo in my MT410 and it is definitely quick and powerful. I can't speak anything about longevity though as I only have two runs on it, but for $48 I can't complain......yet anyways lol.
My initial thoughts are good but we will see if it makes it through a year. Tomorrow will be my first real jump and bash session with it as well as my MT410 so we will see how the servo and my assembly skills hold up, assuming I don't overheat in the 97 degrees.Nice, yeh my shop has the 32kg version of those alloy case JX's and I was thinking that might be my next choice if this cheapy holds up ok.
