PPS Kraton 8s Motor Mount Insert!
PPS-RC
ArrmaForum Vendor
Vendor
Cleveland Ohio
Kraton 6s, Nero
Introducing the K8S 30mm Motor Mount insert!
It is now available for preorder at PPS-RC.COM!
All of the details are covered on the website but here are some key bullet points:
30mm motor spacing only
You can fit up to a 62mm motor
Up to a 44t pinion on the factory spur.
Down to stock gearing.
The pinion must be mounted flipped/reversed on the motor shaft.
Looks sick!
Reuse your factory frame and stock hardware
Hardware is an extra option, and it will include a fancy motor clamp washer yet to be photographed (it has been elusive). It is similar in design to my v4 6s motor mount hardware clamp.
You can get a good overview on BicketyBam's video:
I am already in production on these parts, and the preorder wait will be very short. I expect to have preorders out the door by 3/4 at the latest!
Create account
Log in
