slick2500
Anything will break if you drive it wrong enough.
Community Leader
ArrmaForum Fan
- Rapid City, SD
- Fireteam
- Kraton 6s
- Kraton EXB
- Outcast 6s
- Senton 3s
- Typhon 3s
https://www.primalrc.com/raminator-monster-truck/
FIRST OF ITS KIND
The Raminator Monster Truck is the First of its Kind for 1/5 Scale RC Vehicles:
- Solid Axle Ready-To-Run Monster Truck
- 2-Stroke Reed-Valve 49cc Gas Mini Motorcycle Engine
- 78mm Centrifugal Clutch
- Transmitter-Activated Reverse Function
- Four-Link Coil-Over-Shock Suspension Setup
- Weighs A Backbreaking 80 Pounds
- 32 inches wide, 40 inches long and 24 inches tall
- Largest in-production tires designed for RC
- Raminator licensed Monster Truck Body
Skill Level - Advanced
Speed - 30+ MPH
Engine - 49cc 2-Stroke Reed-valve Engine
Transmission - Single Speed with Remote Reverse Feature
Differential Type - Front and Rear Bevel Gear Differential
Brake - Front & Rear Single Disc Mounted Driveshaft Mounted Manual Disc Brakes
Drive System - All Steel Gears with double chain transfer case drive
Steering - Steering Dual Servo with HD Aluminum Servo Saver
Radio - 2.4 GHz 6-Channel FlySky Digital Radio
Specifications
Length - 40 inches
Width - 32 inches
Height - 24 inches
Weight - 80 pounds
Wheelbase - 24 inches
Tires - 12 x 7.5 inches
Rims - 5.5 in diameter x 6 inches wide
Minimum Ground Clearance - 4 inches, Adjustable
Minimum Chassis Clearance - 4.5 inches, Adjustable
Minimum Axle Ground Clearance - 4 inches
Tracks - 31.5 inches
Servos
- 2x 20kg Throttle/Reverse Servos
- 3x 70kg Steering/Brake Servos
Can be yours for $2,899 before shipping.
