- South Louisiana
- BigRock 4x4
- Granite
- Kraton 6s
- Mojave
- Notorious
- Talion
- Typhon 6s
Here for offer at $75 shipped to your lower 48 US address is a truly barely used:
Radiolink RC6GS 2.4G 6CH RC Transmitter plus 2 (two) R6FG Gyro receivers.
I installed one of the receivers in my Kraton for two packs runtime on the road and it is in pristine condition.
Both receivers are tested and work.
This radio allows the use of AA batteries or a hobby battery pack with jst connector.
Range tested was at least 2.5 city blocks but I didn't have reason to go beyond. This radio and receiver combo is marketed to offer huge range.
- 【6 Channels】: only take 12ms for 6 channels to response parallel, FHSS and automatic frequency hopping technical to keep the excellent anti-interference and stable performance.
- 【Built in Gyro】: come with R6FG receiver built-in gyro integrated to hold the vehicle in a straight line during aggressive acceleration and braking, the receiver support up to 10v of servo.
- 【Dual Mix Control】: RC6GS rc controller supports programmable dual mix control setup, every two channels can be mix programmed. Twin-engine boats or cars such as crawler, drifting, other RC cars and boats on the market.
- 【Fail-Safe Protection】: can be set from CH1-CH6, to protect the safety of the model, low-battery warning function to avoid ignorance in a noisy environment.
- 【Long Range Control】: with R6FG has amazing stable distance control more than 600meters on the ground. Makes rc hobby fun and cool with FPV display or goggle.
I bought this radio and receivers to allow me to get rid of all my RTR radios. It has a 10 model memory so with 10 receivers you can run this radio alone for all 10 of your vehicles. I have zero complaints whatsoever but have decided to go with FlySky because I came into some extra expendable funds.
Will ship in heavy cardboard in original styrofoam and packaging with the quick start guide and manual I printed from RadioLink website.
PM with questions and thank you for your consideration.
