Pro-line Badlands
Uk
  2. Notorious
  3. Talion
Please see picture attached, I'd like to know a few things if you guys could help me out here.
First what measurement is 3.8 size in? As in the unit
Inches?
Secondly what size are these tires in the picture.
2.2 2.8 3.2 or 3.8 this is really messing with my brain ?? my friend brought round his rig for a service and for me to add upgrades to his car, but when i questioned him on the size he said 3.8 but they look small.
Any help would be massively helpful
Cheers
Lol well if you took a picture of the whole truck I’d be able to give you an answer in 2 seconds. I don’t know what those numbers mean on the tire.
Also it appears they have the swappable hubs? They’re probably 2.8’s. Send a picture of the whole truck and I’ll lyk.
Is it normal that you need Balance these tires? Some have need use alot weights like 30g in each wheel i read somewhere.
like 100g plus 4 wheels :eek:
Hmmm i need extra Durable wheel bearings i believe also
My cars is shaking rear when i give full throttle and make bad sound also.
Back to other wheels, no problem. Back to Badlands again the sound comes back.
Can balancing them help me out ?
I don't want that shake and sound
I have glue them well
What can be wrong? I have also Gorilla tape them. They don't Balloon 6s speed pinion
Did you tape them evenly? If you added more tape to one side then that would make them unbalanced. Especially with Gorilla tape because it is heavy. I would put money on that being the problem, or some issue from the added tape.
Hi guys
i have tape them very evenly. I mark and so on.
Also did properly Glue job. Sandpaper tires inside before tape, also sandpaper rims round glue area.
Im not stupid at all :)
Maybe the tape make them sound at max rpm,s because they don't baloon ?
You can only have them offroad maybe ?
I will balance them next week. I will tell more then
Hi guys
I wasn’t implying you were stupid in any sense. It’s just something that would be the first thing I would check is all. Did you check the foam like @Outcastblxnut suggested?
I did Massage the wheels all time, and make properly job . I love glue and gorilla tape .- This is so fun. I need balance now . I be back then with results
One rear wheel did wobble pretty bad when i drive it in air and check.
I got alot of these tires and wheels, i did glue and gorilla tape one new and now the problem is gone.
I did only run the others 2times, foam is fine.
Problem is solved now.
I will balance them also , even if the car goes fine now
I must say these badlands 3.8 are great tires when you gorilla tape them
No balooning.
Awsome grip and handling. Much better grip than stock
Way better than stock Katars in my 6s Talion.
