MolyHoly...
Is that cnhl 6200mah or 9200mah????its hugeShe was on her last legs.
A couple of speed run hits with LVC disabled exposed her.
Sh!tHoly...
COWHoly...
I’ll drain it with this LED.Lol, wow.
You probably already know this, but for anyone else who finds themselves in this situation...
Put that battery, leads down, in a glass bowl or jar of heavily salted water. That will slowly and safely discharge the pack to 0 V so you can throw it in the normal trash. Should take <24 hours in the soak.
No that's wrong. You first have to poke a hole in it with a screwdriver to let the puff out. Then put it on a rapid charge. You may have to poke it again while charging. Trust me this is the best way.So it puffed a little, just balance charge it and it should be good! Wrap it in duct tape and run it!.... Or maybe not
Disclaimer; this method has not been scientifically tested.
Your half way to being correct. More puff does equal more capacity. But 6v per cell is redundant once puffed. 8 volts is required to charge the extra puff. Its called the puff factor.No no no THATS wrong. since it's puffed it has room to hold extra charge. Just set it to 6 V per cell and rapid charge. It'll be good for an extra 5 MPH.
I know it's weird, but this will only work if you video tape it and upload the video to this forum.
