I have been having an issue with my New Limitless doing speed runs. I bought it used with a Hobbywing Max 5 esc with large cap pack and it had a Poseidon motor. I switched to a Cordova 1430 2400kv motor but now as I'm doing a speed run somewhere around 80 mph it cuts out then will power again after a couple seconds. I'm running a 6s Max Amps battery. Motor is not hot and steering never cuts out. Anybody know a common problem that causes this? Once it even cut out right as I was taking off but then cut right back on. BTW, I've been into RC for years so I did the usual replacing remote batteries etc. It's not far away at all when it cuts out so it's not a range issue.
Any ideas? The motor did the same thing in another vehicle running a Castle MM2 esc but I figured the motor was just too much for the esc.
