Dauff
Big problems with 2 new batteries !!! Turnigy Nano-Tech 5S 5000 mah 35/70 C. I can do 1 very fast lap and after that it slows down and nothong is hot ! And the batteri is stil full. What can be the problem ?
The esc doesn't recognise 5s, only 4 and 6s.If you want to run 5s set the esc to nmh setting, that takes it out if lvc mode so you need to run a external lipo alarm.Big problems with 2 new batteries !!! Turnigy Nano-Tech 5S 5000 mAh 35/70 C. I can do 1 very fast lap and after that it slows down and nothong is hot ! And the batteri is stil full. What can be the problem ?
Ok thanks a lot !!! Now i will read how to do this without causing any other problem. Thanks againThe esc doesn't recognise 5s, only 4 and 6s.If you want to run 5s set the esc to nmh setting, that takes it out if lvc mode so you need to run a external LiPo alarm.
