Problems esc please help
brett1
Where is the reset button on the esc need to reset it to factory default. Pictures please I’m a bit confused.
I don't believe this is possible. The Mega ESC's are not programmable, hence the jumpers for mode and fwd/rev, so there's no factory reset.
What are you experiencing that is making you think you need a reset?
Esc flashing red after about 5 minutes of use just wondered if it needed resetting but just been to local hobby shop and they say it will reset when you turn it on and off
Flashing red is low voltage it's not running long enough to be overheating unless you have an electrical problem. Make sure the jumper on the esc is set for nimh if using nimh and the battery is fully charged. If that's all good try a different battery and see if the motor and/or the esc are too hot to touch.
