cooper132
- Thread starter
- #21
Agreed.same thought I had mentioned earlier about what he thought was a hesitation or what he calls stalling was actually cogging..
Cooper could you show me on the side of the esc where it shows it will hold a 3s lipo? Not that I don't believe you but I want to see it visually.if you don't mind thank you
Also I went through this whole thread but have not seen any photos or a vid of what you have ..showing us a vid of what it's doing helps and pics of the system also helps..pics plz
I agree with this for sure.I honestly think he should just go back to what ever was in his rig from stock.he messed around with to much all to quick .that's the problem with doing to much at the same time.things happen then it's hard to trace back.if you do things in small steps then it's easier to find the issue.i still don't like the 85amp esc with that gearing and on 3s to me it doesn't sound right.put everything back the original way.then see if your heating issues is still there which I doubt it will be ..when ever I change gears I do it one tooth amount at a time..I test it out and if it's all good I move on.now if it's over heating at least I can drop one tooth and see if that was the issue.baby steps goes a long way..
