Problems with mojave
Austinrc
I own a 6s arrma mojave and when i bring it outside to run it it starts to drive for about 4 seconds and stops and my esc blinks a slow pace green light and turns but no longer has throttle response does anyone know why this is happening?
I also have new batteries in it I've tried 2 different ones same response
Robbbbbb66
Robbbbbbbbbbbbbbbbbbbbbbbbbbbbbbbbbbbbbbbbbbbbbb66
Hospitality Award
Potsdam, New York, (You-S-Eh)
  1. Infraction
  2. Kraton 8S
  3. Kraton 6s
  4. Mojave
  5. Mojave EXB
  6. Outcast 4s
  7. Senton 3s
  8. Talion
  9. Typhon 3s
Unplug your servo and see if it works on the bench propped up.
Austinrc
correct.
We are trying to see if your steering servo has gone bad and causing some kind of short circuit back at your ESC..
I'm attempting that the screws hold the servo are horribly stripped because I got this used so I need to get it out and I will let you know if that fixes it
Dan B.
Area man
Rig of the Month Winner
Southern Vermont
  2. Mojave EXB
  3. Outcast 6s
  4. Typhon 6s
No man, just unplug the servo from the receiver. You can leave the servo installed for now. Just open up the receiver box and unplug channel 1. Your servo. Then power it up on a bench and see if it seems ok.
PeighDay
I came...I saw...I broke it
Folsom, CA
  2. Outcast 6s
  3. Outcast 8s
  4. Talion EXB
Another option is just unplugging the servo from the receiver box.
Edit: See above post.
Tex Koder
2D , 3D Not a problem. I'll take that Challenge.
Dallas, TX (USA)
  2. Infraction
  3. Kraton 6s
  4. Mojave
  5. Senton 3s
  6. Vendetta
Hey No.
We're NOT asking you to completely remove the steering servo unit. Leave that alone.
We just need you to disconnect the cable from the receiver. To do the quick test..
Just to check it off the list of things to check.
It's the simplest.
Austinrc
Hey No.
It's the simplest.
Ok I did it and it still cut off almost instantly and the blinking green came back
Tex Koder
Dallas, TX (USA)
  2. Infraction
  3. Kraton 6s
  4. Mojave
  5. Senton 3s
  6. Vendetta
Alright..
We need photos.. take pics of your batteries and your rig and let's see what you're dealing with ,so we're all on the same page..
Austinrc
Tex Koder
Dallas, TX (USA)
  2. Infraction
  3. Kraton 6s
  4. Mojave
  5. Senton 3s
  6. Vendetta
Okay.
Looks like you pulled your ESC connector off the receiver..
So you did it backwards.
Put the ESC connector back in and take OUT your steering servo, this time.
And report back.
305HemiGuy
  1. Fireteam
  2. Kraton 8S
  3. Kraton 6s
  4. Mojave
Okay.
And report back.
Either that or the Servo & ESC connections were plugged in the wrong spots, which could be causing the error. If he's certain he unplugged the servo and didn't touch the ESC, then it looks like the servo was plugged in where the ESC should go.
Austinrc
Okay.
And report back.
I already did that I was just trying both when I took the photo but I already attempted it
305HemiGuy
  1. Fireteam
  2. Kraton 8S
  3. Kraton 6s
  4. Mojave
Did it ever function correctly since you've had it, or was this your first time attempting to run it?
305HemiGuy
  1. Fireteam
  2. Kraton 8S
  3. Kraton 6s
  4. Mojave
Man that sucks. This is just my opinion, but at this point it's just a process of elimination. Luckily they're only 3 components that you're really going to have to concern yourself with here, the ESC, motor, and receiver. If I had to take a stab in the dark, I'd say the ESC might be culprit.
