Kraton Program card or Bluetooth module to change ESC setting?
raynist
  1. BigRock 4x4
  2. Infraction
  3. Limitless
  4. Kraton 8S
  5. Kraton 6s
  6. Mojave
  7. Notorious
  8. Outcast 8s
  9. Outcast 6s
  10. Talion
  11. Typhon 6s
Which one is the better option? I like the idea of the bluetooth module as it works great on my traxxas vehicles. I haven’t read much good about the spectra one though.
If a card is the better option, which one is the best?
Thanks!!
The question would be on how many times are you going to reprogram the esc ?
If once or few times toGet it right, then none of them! And better spend the money on other upgrades or somewhere else.
On the other hand, the card or the esc directly, is almost the same (did I say almost?) then I would go for the Bluetooth
I just used the ESC to change the settings. It was pretty easy. I think once I get them set the way I want I will not change them.
I only changed punch from 3 to 4 and braking to 50%
