- Massachusetts USA 🇺🇸
- Limitless
- Kraton EXB
- Typhon 3s
- Typhon 6s
So I’ve decided on the project 3scf as my newest rendition of my latest project with the rebuild of my crashed typhon v5 6s. It’s going to have a custom cut by me carbon fiber chassis, that’s approximately 40-50mm longer than the typhons stock chassis, the ext length should not require new drive shafts, since I’m making a custom cut 75mm-100mm spool. Depends on length needed of stretch. I’ll be using limitless tower# and shocks, pps motor mount, hopefully gp5 diffs. Arrma typhon arms with kraton hubs and stuff. Grp wheels should be fine for a 3s vehicle. Oh yeah it’s also going to have a belt drive spool and motor belt drive, no regular pinion. That gives me much cooler gearing to play with. I have a new body I’m going to try it’s a bit different then the regular typhon body
It’s kinda like this but much better
I haven’t decided on the motor or esc yet, I have a few to choose from. From a stock arrma 6s setup, a torox 185, HW max6, or the CC XLX2, for esc’s. Motors I don’t have any expensive ones simply I can’t afford one yet, but I have a few to try a neu castle 1521 2650kv, HW 4985 1650kv, a rocket 4092 1420kv, or a spectrum 2050kv stock 6s motor. I hope one combo will go decent I’m looking to break 120mph. So let me know any thoughts. I am slow at projects, and it may change again lol but I got the carbon fiber chassis almost done being rough cut, after a few decisions I need to make on final width and whether or not the front needs the kick up or not I can’t see the reason why still. I might put an aluminum front kick up or not
