- Wenatchee, WA
- 4x4-Mega
- BigRock 4x4
- Felony
- Granite
- Infraction
- Limitless
- Kraton 6s
- Outcast 4s
- Typhon 3s
- Voltage
So my first Arrma was the Arrma Voltage and have since bought/built up many other Arrma models and the Voltage just doesn't get run that much at all. Since it's not really worth selling and I don't really have any uses for it I slowly been doing stuff to it just for fun. I been randomly modding the truck since January and thought I'd share since the Voltage doesn't get as much love around here
Current mods:
Upcoming plans in the future if I don't lose interest and get around to them:
Current mods:
- Brushless 60A no-name ESC (supports 2s or 3s) + 3650 sized 4300kv motor + FlySky FS-GT3c radio/receiver
- Arrma ADS-15M Servo
- T-Bone front/rear bumper + wheelie bar (like it needs a wheelie bar but still)
- Metal diff outdrive cups with locked rear diff
- Speedtread Speedhawk wheels/tires
- 40mm/5v fan w/ blue LED in it, originally intended for a Raspberry Pi I think
- My own designed 3D printed top plate
- Currently a prototype, more work to be done on this. Designed in a way that the underside has rooms for cable management, making install cleaner
- 3D printed receiver box
- Arrma 3s/4s wing mount with turnbuckle rear braces to secure the rear to the body
- Custom 3D printed TPU wing
- Upgrade to better ESC/brushless motor (probably will use something I pull off another truck if/when I upgrade one of those to something else)
- Refine the design for my Lipo "Saddle Bags"
- These are 2s Lipo battery trays I design to add to the sides of the chassis so I could run 4s with 2 x 2s packs. I may or may not make it so I can keep using the stock battery bay. These are shown in the pictures but not yet functional and more so there for proof of concept.
- Refine 3D printed top plate and make it a multi part print with incorporated mounts for a printed receiver box, motor fan mount, and mounting points for lipo saddle bags.
- Might even abandon saddle bags and just widen the tray with additional body mounts/supports and lay it out more like the 3s chassis layout
- Replace stock shocks with metal oil filled w/ stiff springs
- Replace plastic turnbuckles/end links with metal/adjustable
- Replace stock steering horn
- Design custom lower skid plate intended to reinforce the weak chassis and mount with top plate and/or lipo saddle bags
- Design custom motor cover, wanting to make one would allow me to fabricate a custom made slipper/spur assembly to replace the weak plastic spur/gear combo
- Fabricate a way to replace the crappy plastic motor mount points and add a dedicated plate with adjustable mesh
- Kind of a just a wish at this point, not sure if it can really be done with the voltage chassis how it is
