I bought a set of each to try,while i like the traction ,from the factory these come glued and on one set (Mx38) two tires are pretty crooked and on the other set one tire/ wheel is glued crooked also.So the question is:What is exceptable,do i return them?Is this the norm with proline?
The Smaller badlands work great,but theres not enough ground clearance,so my chassis heats up from the hot sand(140f).With the Mx38's my Kraton runs cooler with the same pinion and is alot faster.
Also have the Hpi Goliath tires and there glued pretty true and also work great on 4s( just as fast as it was on 5s).
