Alexander Herbert
- Kraton 4s
You cut the mount off flat just below the clip holes and use 1/8 drill bit and drill the centre of the mount about to a depth of half the length of the threaded piece. Use a 2mm driver and screw it in. All 4 took me less than thirty minutes. I would use an awl to make an indent in the post before drilling so the drill doesn't walk on you.So how do you mount the threaded piece into the body post?
don't buy the post kit. You only need the tops and screw postsI was interested so I bothered to watch this.
I'm sold!
Not sure if the kit fits the Arrma chassis, need to do some further research unless someone can confirm.
