- San Antonio TX
- Felony
- Granite
- Infraction
- Kraton 8S
- Mojave EXB
- Outcast 8s
- Typhon 6s
Yeah, the Max 6 and 1650KV motor 23T pinion are the best for the Mojave. Or the MMX8S with the 1717 motor. But on 6s only. On 8s, the drivetrain just gets destroyed much faster. And the bearings explode. Even the front hubs got worn out on the inside on 8s. 6s, 23T pinion gives you 50+ MPH speeds. But I would put a couple of 35x35x10 fans on that 1650KV motor .The bad of the mojave might be the rtr diffs. It has small tires like the typhon but extra weight. Good enough so the diffs do not explode? Idk. The bumper springs and body mounts break every run almost. Unless u have a 3d printer and can print flexible or buy them 3d printed from someone its something ur going to be changing a lot. And painful to change specially the bumper ones. The body post ones are easy. Car is durable but the body gets destroyed on the rear end specially. Likes to tractiong roll and the wheel hexes can strip if you go too crazy on the stock tires
Stock system is a bit under powered and control in the air does not exist
