- WA
- 4x4-Mega
- BigRock
- BigRock 4x4
- Granite
- Senton 3s
- Typhon 3s
Prove this is your first time changing your shock oil
Yes those were my old stock shocks I just got new proline ones…I thought why not see how bad the oil is. I agree it’s not dirt. Shock shafts are bent to lolYou could put brand new oil in a shock, move it up and down a few times and it will be black from the piston friction on the exposed internal aluminum shock body. Much like taking aluminum polish on raw aluminum, turns black instantly.
Some think it’s dirt. Had this discussion a few times.. BUT, if it were dirt, the bladder and O-ring would be bad and leaking for dirt to get in. Don’t believe it, put new oil in and go up and down a few times, dump the oil and wala, black oil..
^^^You could put brand new oil in a shock, move it up and down a few times and it will be black from the piston friction on the exposed internal aluminum shock body. Much like taking aluminum polish on raw aluminum, turns black instantly.
I polish my shock shafts mounted to a drill. I use a Jewelers Rouge/Flitz when I do a complete shock rebuild. Any metal polish is good. Makes for a bit more plushness, less wear and sticktion at the O-rings. I only use an Alloy Tekno Shock Multi-Tool to mount the shock rod ends. It also pops balls easily. There are others much cheaper. A worthy tool for any RC toolbox. I never use standard pliers. Damages the shafts.
