- Thread starter
- #21
Thank you, I honestly had no clue.
‘Brushed’ aluminum looks very nice.Nah, no need to waste the time... I already hit the bricks on the side of my driveway... I'll have them natural color after a few battery packs!
Perfect!Fixed![]()
I'm headed more toward the scraped and scarred finish.‘Brushed’ aluminum looks very nice.
I’ve been working on that look for quite awhile…on myself I mean. Never a dull momentI'm headed more toward the scraped and scarred finish.
Without having to use the typhon specific axles or did you switch those also?I put the Typhon 17mm hub on my Vendetta. I only had to gring the backside on the hub flat. After that. Goes on easy. Put GRP'S on it.
I used the Vendetta axles. I didnt trim the body either. I thing I went up 1 body post hole in the front and 2 in the back. Or maybe the other way around. I also have a carbon fiber splitter on it. Turn the wheel left and right no rubbing. I saw a guy on youtube do it.Without having to use the typhon specific axles or did you switch those also?
How much did you have to trim off the shell to fit the larger tires? Thanks man!
Nice! I remember seeing your post, at least the picture. I have the infraction and I think I will try your raising the body post idea to put larger tires on it. Interesting about the typhon hex also. For some reason I only thought they only worked with the typhon and axles…thanks bud.I used the Vendetta axles. I didnt trim the body either. I thing I went up 1 body post hole in the front and 2 in the back. Or maybe the other way around. I also have a carbon fiber splitter on it. Turn the wheel left and right no rubbing. I saw a guy on youtube do it.
How is this holding up? Still no body rubbing issues? To clarify, you only bought these hubs and nothing else?I put the Typhon 17mm hub on my Vendetta. I only had to gring the backside on the hub flat. After that. Goes on easy. Put GRP'S on it.
