stuartd
I've had my Talion for around week and there's a bit of wheel wobble. When looking at that I noticed a couple of things that weer different between the front and raer of the car.
At the front I'm able to push/pull each front wheel side to side and see the dogbone and input shaft cup move laterally along with the wheel by 1 - 2mm where it 'slots' into the wheel hub. Each front left/right dogbone/shaftcup/wheel moves laterally.
I've removed (the hex nut was tight) and reattached the tires which hasn't made any difference.
At the rear both dogbones have about 5mm lateral movement within the input shaft cup. They're not close to falling out, but I didn't expect as much movement as it's not present at the front.
Is this normal or have I managed to break something?
This is my first proper RC car (I had no idea what these parts wer called until I checked a labelled exploded diagram) so I'm starting off with very little knowledge other than what I've picked up fropm google, youtube and forums.
