Typhon Question about steering links on a typhon with mojave arms
N.Mango
I swear the voices are real!
Hospitality Award
Rig of the Month Winner
Build Thread Contributor RC Showcase: 12
Kapaa, Kauai
  1. Kraton 8S
  3. Kraton EXB
  4. Typhon 6s
My last Typhon that I had, I put Mojave arms on it, but for the life of me,
I can't remember if I needed to change the steering links.
Does anyone know if the stock Typhon links have enough length to use with Mojave arms?
(not that I'm going to mod my new Typhon or anything:devilish:)
Mojave links
I'd definitely go with Mojo links. Even if you can extend the Typhon links enough there would be far too little engagement between the links/rod ends. Likely pull out as soon as ya get ur tip wet. LOL
Great advice! hahaha
I’m running Mojave arms, driveshafts and links. Kraton hubs and hexes. ADU shock towers and center chassis brace, strc front and rear chassis braces. Spektrum 150 amp V2 esc (updated) with a team corally kuron 2050KV. It screams!
Nice build, sounds like a tank. I did the K6 chassis w/Mojo arms, shocks, ect. Basically a Typhon XL or TC Asuga. One of my favorites. I had a 1450kv 4274 leftover from a previously failed project, which is now in my Typhon XL, along with a Hobao 150a esc, 20t pinion, 6s. Darned thing runs for nearly 25 minutes on a lowly Zeee 5200 6s brick!! Awesome!! Has PL Mirage TT tires on it now, Fortress when the ground is soft. Make it ur own way I say!!👍😁🍻
Hell yeah man!! Right back at ya, sounds like a sweet setup! I am running Kraton springs as well. Definitely helps for big sends, I am going to be trying new tires soon as these are really only good for street to grass jumps. Not much traction in grass at all😆 but make it your own! The best RC is the one that puts the biggest smile on your face!
Noob question.
What's the advantage of having Kraton hubs?
