I did fit them but never run them, Chris (Heya did you ever end up fitting the backflip LPs? Wondering if it’s worth getting a set if I ever see them at Jenny’s...
HiInformational Post:
Question: Can you move the battery tray backwards on the Mojave 6S?
Response: Yes, you can and you get all the required mounting holes to line up as well.
As you can see below all 5 mounting holes will line up as well if you move the battery tray and receiver box backwards. So in case this was nose heavy at one point there is opportunity to counter it.
Still not the optimal solution for what I got in mind. I am thinking to keep the receiver box where it is and get a complete different battery tray to accommodate for my needs - further testing/exploration required.
I think the battery tray in the Mojave 6s is a weak design and does not hold big 6s batteries that well. What sort of Mod would you recommend for the battery tray?
Thanks
Maybe the battery tray came loose because I shifted it to the back. It landed on the back bumper. The jump was not high at all but I suppose it was violent enough to dislodge it or maybe I should attach it together with the receiver box. So I followed the modification and shifted back to the front. Am very happy with the mod because it is firmer.How does the car balance with the battery tray shifted back? Better in the air?
