roger nelson
- Fury
anyone have a favorite aftermarket radio system? Favorite radio system under 100 bucks? 200 bucks?
Do they have them in green with a soda cooler?...![]()
....and the best part is it will bind with the stock receiver that is currently in my Fury BLX. ...
I heard this rumour before.
Did you try it yourself?
HobbyKing is offering those FlySky's surface radios under their own brand name.
I have tried to bind it with my Arrma receivers, but it did not work.
No, haven't tried this personally, but I remember reading somewhere that it should work with the FlySky transmitter. I believe that the Axial AR-3 and Arrma ARX100 receivers are both made by FlySky (heck the Axial AX-3 and Arrma ATX 100 transmitters look identical), and I know that others were able to bind the Axial AR-3 to the FlySky GT-3C. But don't quote me on that, it may just be hearsay.
Even if it doesn't work, FlySky receivers are going for $7 on eBay and $10 on amazon, so no big deal.
Has anyone done a conversion to Spektrum DX4C/S with a 4210 AVC receiver? I have an Arrma Kraton and I think this would suit me to be able to do that conversion.
It's not the cheapest option but it would allow for use on other models as well, has a couple of extra channels too!Well...I am saving up for it...
But it will be January before I can give you my verdict..
So anyone else can say something about this receiver/transmitter set-up...It would be much appreciated...![]()
I see, that sounds like it's a good fit for me. I guess I need to know what's involved in doing the conversion, I'll need a digital servo won't I ? And can I use the receiver box that it in the Kraton now. I'm just getting back into the r/c field again and these 2.4 systems are all new to me!! I remember having to swap crystals for different channels!! Does this show how long I've been away?!Check out my post on the dx4c above if you missed it. That is one bad ass radio system!
Great to know. Thanks.Yes, a digital servo is required for the avc. Not sure about your receiver box, but the one on my granite was too small. The receiver is waterproof so I just got rid of the box.
