@SrC ,I run that setup. RC6GS/R7FG.( Lim/with telem.). 2-3 minutes is surely splitting hairs, and I see no relationship with run time and Telem at all. Telem uses minute signal voltages on the BEC circuit. And the Servo if anything uses most of the BEC amps anyway.
If anything, signal Latency would be a hit using Telem as indistinguishable as it is.
It has to be for other reasons, IMHO. And still 2-3 min. is nothing. Lipo run times always vary. Never the same. We all drive differently every single time. So run times will always vary. There is no way to discern 2-3 minutes as a constant difference every single time.
What exact Telem data are you set up for right now.????
