44Dan44
I'm not superstitious, but I am a little stitious.
Military Veteran
Rig of the Month Winner
- Friendship, Maryland
- Felony
- Fireteam
- Outcast 6s
- Talion
- Typhon 6s
Hi all, just a hack to raise the Typhon body to fit whatever you want under there. Can we call this the 44Dan44 solution©? Then maybe Arrma will give me some kickbacks on the V6 Typhon. If it’s been done before I haven’t seen it or they didn't share it.
This works for the short wheel base (stock) as well as the stretched Typhon crew. Pictures are worth exceedingly more than words so I’ll shut up after sharing the various threads discussing this and let the photos start talking to you. Disregard my high tech rc stand.
This has been discussed before and a video provided by @Edough13 which gives you a little bit more clearance short-vid-describing-how-to-raise-body-for-dual-3s-packs.31808 by raising the rear mount one screw hole and drilling a new one.
This thread to fit big fans
“typhon”-12v-40mm-fans-wired.43175
This thread discussing heat under a tight body shell
pinon-gear-wont-go-on-new-brushless-motor.47860
This thread trying to fit certain batteries
battery-body-fitment-issues.48786
This one looking for alternative bodies to fit more under the hood
alternative-bodies-for-typhon-3s-blx.45284
This one discussing fitting certain heat sinks
motor-fan-for-typhon-s6-v5.35628
This one about stacking hard case batteries
can-the-typhon-6s-use-two-3s-lipo-batteries.39822
This one regarding motor cooling
better-motor-cooling-for-typhon.39444
This one about fitting Spektrum batteries
spectrum-6s-smart-lipos.48389
Just wants a little more room
how-to-raise-rear-of-typhon-body.13047
Another for dual 3s packs
typhon-battery-tray-too-small.39163
Heatsinks again
which-heatsink-fits.34469
Choice limited by body clearance issues
new-v5-typhon-6s-has-arrived.30006
Buying batteries based on size constraints as a solution
2-x-3s-or-1-6s-battery.39274
Etc etc etc
typhon-3s-vs-6s.30364
Heatsinks again
Etc etc etc
