- Kraton 6s
- Notorious
What is the o.d of our stock antenna tubes on the kraton/notos(6s), my cats are dinks and chewed my old ones so I can't measure them to order new ones on amazon
I don't want the stock one or I would have just ordered that I need the o.d of the antenna tube to order better longer ones from amazon. Thank you though.Part# ARA390001
Perfect thank you very much. ones on amazon will work. Using a dumbo rc remote so not worried at all about minor signal loss if the material is a bit thicker.Gotcha ?
Does this help instead?View attachment 104498
I have two 6 channel remotes and 4 receivers with gyros except 2 are missing the antenna wire...damn catsNice, Did you get the gyro dumbo??
You solder them on but its a pain as the pads are super close to each other and its hard not to solder them togethor.You can get replacement antennas on ebay but unsure how to solder or attach them ??
N nice, I'm planning on getting a 6ch Dunbo with Gyro soon for my Krayphoon ? after I Finnish my upgrades
same my nitro traxxas can get abt the same range tbhI just got a Dumborc and range is about the same as the Tactic, which is pretty good, but from all the hype I was expecting much more range. ??
I have rechargeable from ikea very high quality batteries(aa). Last time i charged them was 1 year ago. so i will chrge them and tryTry rebinding them and make sure you have good charged batteries. I had range issues too and that worked for me. I had both my rigs out with their dumbo setups and one had fpv going and we had great range. I can't see my car before it runs out.
They came bound from the factory, so I will give that a try and see if it makes a difference. Am getting about 500ft right now before it starts getting laggy.Try rebinding them and make sure you have good charged batteries. I had range issues too and that worked for me. I had both my rigs out with their dumbo setups and one had fpv going and we had great range. I can't see my car before it runs out.
Rechargeable batteries have a lower voltage. You should just use alkalines or use a lipo pack.I have rechargeable from ikea very high quality batteries(aa). Last time i charged them was 1 year ago. so i will chrge them and try
I do in my Futaba radio. If using Nicd cells (1.2v) then you’re only giving it 4.8v total. With fresh alkalines (1.5v) you’re giving it 6.0v total. A fully charged 2S lipo is 7.4v. The website says 4.8-12v for the transmitterI can use a 2s lipo. I have heard that is it true?
I use rechargeable batteries they work perfectly fine. I had a 2s futaba battery but the thing blew up so went back to rechargeable batteries. I Have great range no lag and no issues. You should always rebind when using a new transmitter never trust the factory bind. You should bind setup the throttle and calibrate esc everytime you put in a new receiver. Like the first thing you learn about rc at least it was for me.I do in my Futaba radio. If using Nicd cells (1.2v) then you’re only giving it 4.8v total. With fresh alkalines (1.5v) you’re giving it 6.0v total. A fully charged 2S lipo is 7.4v. The website says 4.8-12v for the transmitter
I did the throttle calibration just not a rebind. I will try that and report back.I use rechargeable batteries they work perfectly fine. I had a 2s futaba battery but the thing blew up so went back to rechargeable batteries. I Have great range no lag and no issues. You should always rebind when using a new transmitter never trust the factory bind. You should bind setup the throttle and calibrate esc everytime you put in a new receiver. Like the first thing you learn about rc at least it was for me.
