- Notorious
- Talion
- Typhon 6s
Ok, first off, I am not planning to do this! I said that first because I don't want to get replies warning me I'll break stuff if I do.
This is just a question because I want to do a custom build on a 2wd Bandit buggy and want to run belted Badlands MT tires in the rear and Badland buggy tires up front. That made me wonder why a 4wd buggy might have issues with it based on what I've read so far about different tire sizes.
When I've seen people mention running rear tires taller than the front, there is always a mention on changing the diff gears to accommodate. I am curious what this would do to prevent issues with the different tire sizes. When running same size tires with a low center diff fluid weight, the front tires tend to balloon more. That makes them a larger diameter than the rear. Wouldn't this cause damage over time if it was an issue running different sizes?
Again, not planning to do this, just trying to understand what makes it different.
