razorrc
- BigRock
- Gorgon
- Granite
- Kraton EXB
- Kraton 4s
- Mojave 4s
- Outcast 4s
- Outcast 8s
- Outcast EXB
- Senton 3s
Figured I'd start my own thread on my truck and include tips, videos, etc.
Today I installed a Kimbrough Large servo saver, seems like it's stiffer than the stock one (which I think is too weak). You can also get the HD version in black, I'll try that one if the white one isn't strong enough.
It's the exact same size as the stock servo saver, just need to trim the rectangle into a triangle so that it clears nicely.
Drill the hole out to 2.5mm to thread the screw through, and use a nut on the other side to secure it.
You will need to space the servo up 2mm because the saver sits lower than stock. I used TLR spacers from part TLR231083.
