Premium members don't see ads. Click here to upgrade.
Granite RazorRC Granite 4x4 BLX build
razorrc
Granite
Just picked up a Granite 4x4 BLX at my local hobby store. Pretty excited, haven't had a monster truck since I bought a Stampede 4x4 VLX 5 years ago, and that cost $430! Nice to see Arrma making an arguably better truck for $130 less.
Will be doing some basic bashing with the truck, and also going to try tuning it for some track fun at my local indoor track, 'cause that's where I spend 95% of my time driving. Not going to do anything too crazy, mainly just get it handling/driving as good as possible with some simple tuning.
bicketybam
BickeringBam - YouTube Mega Star!
ArrmaForum Fan
New Milford, CT
BigRock 4x4, Granite, Notorious, Talion
A little unboxing video...
I usually don't care for unboxing videos but you did a great job. I think you are going to have fun with the Granite. It actually handles pretty nicely for a MT. See if you can wrangle up a 3s battery and try that along with 2s. It's so much fun on 3s.
razorrc
Granite
With the Duratrax 12mm hex conversion (DTXC3596 ), I tried a few different short course wheels. Associated SC5M/SC6.1 +3mm wheels barely fit, but they look like they would rub a little bit in the rear. Losi wheels would definitely be too narrow. So it looks like these are made for Slash 4x4 wheels, will borrow a set from a buddy and test them out. IIRC, Slash wheels offset out the most.
razorrc
Granite
Out of interest , why would you be bothering with SCT wheels on a MT ?
I'm going to set this up next week as a 4WD 1/10 stadium truck/truggy for some racetrack fun. There's a lot more selection in race tire compounds and patterns in SCT tires.
Curvin
Melbourne, Australia
4x4-Mega
Fair enough, that makes sense.
Slash 4x4 run a 9mm offset , so should clear what ever is fouling atm with the 3mm offset.
razorrc
Granite
What the heck? The slipper bearings are unshielded and after 2 packs at the basher track one of them was already seized!
Gotta replace these right away kids, get some 10x15x4 shielded bearings.
Edit: so far every bearing I’ve gotten to has been unshielded... :mad:
razorrc
Granite
I have to say, the U-shaped holder for the ring and pinion diff gear is brilliant. It's probably not obvious, but there are a lot of little advantages. It ensures you can check the mesh of the ring and pinion, and also the smoothness of all 4 bearings at the same time. It also makes it super easy to get the pinion gear bearings out because it splits in half. Lastly, you can easily check or modify the shimming of the diff left/right without closing up the diff case.
razorrc
Granite
Tip #391 -- when putting the pinion on the motor, set it to 2mm off the end of the motor shaft. You can't tighten it after it's in the motor mount, so just do that and it will be perfect.
bicketybam
ArrmaForum Fan
New Milford, CT
I think I'm going to try the 20t pinion on 3s.
Jerry-rigged
Have you seen my LVC?
ArrmaForum Fan
Texas, Baby!
4x4-Mega, Kraton 6s, Typhon 6s
Looks like a fun playground!
(Wish I had something like that close to me)
bicketybam
ArrmaForum Fan
New Milford, CT
Was that 2S or 3S. I'm guessing 2.
razorrc
Granite
It's a good ol' time. Some kids on bikes crashed hard on the right side when trying to go into the bowl, so I'm thinking about renaming it the blood bowl. Lots of broken RC parts in there from past cars too!
razorrc
Granite
Finished upgrading all my bearings to rubber-shielded bearings. You'll need:
(4) - 5x10x4 steering bearings (replaces plastic bushings)
(4/6) - 10x15x4 slipper/input shaft bearings. I kept the two inner ones on the input shaft since they aren't exposed, but you could buy 2 more for that.
(4) - 6x12x4 wheel bearings
(8) - 12x18x4 wheel and diff bearings
The metal ones didn't last long, they aren't fully sealed so dirt gets in them, especially the rear input shaft bearing.
Revomikey Arrma 4x4 6
kruski Arrma 4x4 6
Porschetech Classifieds 0
C Arrma 4x4 2
Similar threads
