- Nero
- Thread starter
- #101
Awesome man, i used to think I didn’t like the way these cars looked but that quickly changed once I owned one... I’m stoked that they come with extra bodies and I bought 2 so i had a couple custom bodies which only made their beauty even better so I hear ya! What color you planning for your second body?My Kronos XTR arrived tonight! It's a gorgeous truck to look at and admire, quite striking and detailed.
Threw all the electronics in (stock Corally setup) however need to wait until tomorrow before a test drive. I did whip it up and down the hallway until wifey gave me the look.
Does the Kronos RTR really come with the 7225 servo? It's what I've used in my XTR and it seems underpowered for this size of car so I'll be looking at upgrading it as soon as I can. Would increasing the ESC BEC help at all?
P.s. I found a small black rubber o-ring on the table when I had finished. Only thing I dismantled was the receiver box (to route wiring), the motor mount to mount the motor and the top roof brace to set pinion mesh without my view being obscured. Any idea where it comes from? If you look closely you can see it near the left rear wheel.
I am planning on throwing the stock system in the second one when it comes back here in the next week or so.. then I’ll be comparing it to the kraton with a stock spektrum system in it. Looks like @BashingBrian figured out your o-ring! If your servo is rated for higher id crank it up to the max the esc has available.. and if your planning to swap the servo anyways I might run it at 7.4 anyways haha. Did you go through the diffs? Mine were pretty low on oil when I received mine. But it wasn’t dry and that I was thankful for.
