Rear diff housing and shock tower?
SentFlying
DFW
Infraction, Limitless, Kraton 8S, Kraton 6s, Kraton 4s, Notorious, Outcast 6s, Outcast 4s
So I stripped the 4 diff housing screw threads on my outcast 6s and need other options. Longer screws with nuts? Metal diff housing? What screw wont snap off if I go the metal housing route? Where to get metal housings as I've only seen one and it was sold by a forum member.
Anyhoo what are my options? Already tried the zip tie fix.
Clubin
Jennys Rc pick up a compleat new diff. Best option.
jondilly1974
Speed running rookie, 3D printing fool
Toledo, OH
Granite, Kraton 4s, Typhon 6s, Typhon 3s
You can simply add in some other material into the holes to get the screws to bite again. I like using a small zip tie cut to fit into the hole. It will snug up fine. Others use a dab of CA glue to help lock it in. That's optional IMO. Another item that may work would be some steel wool. Shove a little bit in there.
SentFlying
DFW
My B-day is coming up, so im thinking upgrades. I have been thinking of getting a thick chassis and figured since the threads are stripped another diff housing. Do the metal diff housing threads strip or snap screws easy? I'll add something to the threads zip ties still let loose. I'll likely pickup longer screws and nuts as well.
olds97_lss
Bash Break Repeat!
Dekalb, IL
SentFlying
DFW
Do you by chance know the thread count on the 3mm? 48 or 56? Looking at fastenal as I have a few local. Are there any other sizes I should pick up while there? Im liking the HR housing. Kinda cool.
New diffcase/bulkhead and be mindful when tight is tight. I think you can use a bit longer screw on the top holes, but you may need to drill it deeper. I use 3mm cap heads anywhere there's a button head I can replace. Makes it less likely to strip the head using 2.5mm cap vs 2mm buttons.
Hot racing makes alloy diff cases, the diff cap itself is a separate piece. They aren't cheap.
https://hot-racing.com/?partnumber=AON12E01;c=1058
https://hot-racing.com/?partnumber=AON12C01;c=1058
olds97_lss
Bash Break Repeat!
Dekalb, IL
M3 .5mm
These are the kind I buy, not sure what length for that specific part though, this is just an example:
https://www.mcmaster.com/91290A123
SentFlying
DFW
Yea, so I'm buying from them... 😁 they are better in quantity and price vs fastenal... Just gotta get a longer size. Thanks!
olds97_lss
Bash Break Repeat!
Dekalb, IL
The shipping isn't cheap, when I buy there, I usually buy quite a bit to stock up because I think it's minimum of like $10 to ship, they use UPS. Not the most cost effective when your buying a bag of washers and nuts that costs $12. lol!
SentFlying
DFW
Well fastenal is $3 for 10 screws 15mm longer and 10k more tensile strength. where as that one you posted shows pack of 100 for 10 bucks. Quantity out weighs shipping i take it.
SentFlying
DFW
Ok will do. For grins I swung by a local fastenal and they don't have any m3 cap socket bolts in the whole DFW area!....😳😔 sad as the wife says she wants me to take the kiddo bashing. Ugh... No luck at HD or lowes either
SentFlying
DFW
Ok, so I ordered online and picked up a 50pk of 20mm 3m socket head bolts and locking nuts from the same location that said no locations had any...😒
The top rear diff bolts are a little short to put bolts on, so I'll try 25mm in those next. The lower bolts are long enough that the end of the thread sits flush with the nylon insert in the locking nut. No drilling required to run the screws through the diff housing ears was needed. They just run straight through.
Made some 15ft high jumps and nothing broke. Later I managed to ram a 4x4 sitting in a ditch and tore off the front bumper lmao! Ordered a. The t bone thrasher front bumper for the kraton. Hope it fits my outcast 😆
Create account
Log in
