th.son
- Senton 6s
Hi,
I apologize if this has been asked 100 times.
I am replacing the rear gearbox/shock tower (stock) on my Senton 3S BLX. When I took the rear gear box apart I noticed that the top part has a bit of oil/silicon in it. I am not sure if it is placed there intentionally or if it gets sprayed up there as the gears turn.
I have a few questions regarding this:
Any advise would be welcome.
Cheers
- When I replace this piece, do I place a bit of oil/silicon in the top part of the gearbox?
- In the Senton, is gearbox filled with oil or silicon? Based on what I am seeing in the forums, I see some references to oil and some to silicon.
- For now, I will probably just stay with the stock weight (I hope I am saying that properly).
Cheers
