Got a new set of springs for the K6 4990 to go on the new longer V5 Kraton shocks. These are Fireteam springs. 1.7mm wire diameter on both. Same overall length both sets. Little stronger spring rate than the V5, which are 1.6mm diameter rear & 5.0lb/in & 1.7mm diameter front & 6.2lb/in. Fireteam are 5.54lb/in R, & 6.91lb/in F. V5 weighs 10.67lbs, EXB 12.24lbs, & a Fireteam 13.77lbs. My K6 4990 weighs 12.3lbs with 4s backflips. Should be good if I go to 6s BFs.
