Outcast Rear sway bar attachment
robl45
The plastic piece that holds the rear swaybar appears to have pulled off. I'm trying to put it back on and it appears that it just has 2 screws that hold it in. I tighten the screws all the way, it seems solid and then I compress the suspension and the sway bar pulls right out. I'm trying to figure out if its just those two screws that hold in the piece that holds the sway bar on or maybe i"m missing something.
Hope this helps mate. Just got an outcast recently so I can't really help u but this is what it's suppose to look like ;)
Thanks, I"m guessing, I have it right, the plastic must just be slightly deformed. I'm a bit ticked that a part that clearly will probably break quite often apparently is only available as part of the diff case.
Yeah i did notice that. Sucks ya gotta buy it as a pack not single
