ibocain23
Back left wheel won’t come off. I thought I skimmed over a thread on here that said why but I can’t find it. O6S EXB. Also both back wheels are really wobbly. Normal? Ask about the warranty? Upgrade to hot racing blocks?
Or use a rubber mallet. That's what I useTake both thumbs and push hard on center of hub wher the wheel nut goes. Wiggle the snot out of it and pull hard. Wiggle back n fourth up n down. You will have to persuade it
I guess it's the friction between the tires and the hubs. Plastic going into metal. Your hubs might be bent. I think it's inevitable with big jumps. Have you jumped it with big air? Honestly, I just run my bashers when that happens. It doesn't really affect the stability that much.Why does it happen? QC issue? Also if the rear wheels are a little wobbly is that okay?
