Typhon Rear wing won't fit
HZRDOS
  1. Kraton 4s
  2. Outcast 4s
  3. Outcast EXB
  4. Talion EXB
OK - so I ordered this larger wing - Arrma website says it fits the Typhon....but is will not unless I have higher wing mounts? Front of the wing hits the shock tower. Am I missing something here? Typically if another item is needed - the Arrma site will tell you -but it does not list anything else needed - makes it seem like a direct fit?
Are your wing mount screws bent up pushing the mount forward?
The mount point at the rear on some models is adjustable, remove the screws on the sides and you can tilt and lift the wing back slightly?
I decided to try a custom fit. I like the lower profile versus getting a taller mount. Cut out the lower front center...I like it.
That looks like a kraton wing, and the kraton has a different wing mount for sure than the typhon. The typhon wing has notches to fit close to the tower.
