Granite Rebuilt my old granite motor…
Velodromed
Snatching defeat from the jaws of victory!
San Antonio, TX
  1. BigRock 4x4
  2. Granite
  3. Kraton 6s
  4. Kraton 4s
  5. Notorious
  6. Outcast 4s
  7. Vorteks
  8. Voltage
  9. Infraction 4x4
It went great! Thanks to many months advice on here, YT and… the bread trick 🤣 which impressed my kid. She was as amazed as I was!!
I used the black part of an MIP hex to push out the main bearing and a socket with the same diameter as the bearing to press a new Jim’s bearing in. One thing I appreciate about my obsession with buying parts and tools is when I need one it’s there, often two of them. Its great really.
Motor wasn’t bad at all and a good rinsing (CNC elec contact cleaner) took care of the dust. The main bearing was rough but I already knew that based on the motors performance lagging. I’m thinking makes the hassle of running a dust cover and pulling the motor module out often to clean worth it. I think that sealing the greased o-ring and washer under pinion really helps keep dust from the front bearing. This motor made it nine months in pretty dusty conditions. Its my favorite car also so gets a lot of run time.
What's the bread trick? Haven't heard about that bevore.
😂 Can't believe this actually works. I'm gona change that bearing just because i want to se that work. 🤣 I love these tricks, thank you all for sharing this with us.
It’s an old school mechanic trick for removing a trapped/contained bearing, like the one at the ass-end of the motor can. Google it on YouTube and you’ll see. Crazy how good it works.
