Been using the Hobbymate D6 Duo Pro with the PSU with no issues.(Firmware updated)
What was the reason for the firmware update?
I just updated it new out the box. No baseline to compare performance difference. Reading around, some stated more accurate balance circuit voltage reads. Can't confirm otherwise. My 6S lipos get along well with the Duo Pro and a PSU. .What was the reason for the firmware update?
Probably. 12v.That is one sweet charger.
Will it handle my 24V 400watt PSU? Whats the Max input voltage for this HTRC?' I dual charge 6S 6000mah 50C bricks.
Tempted to get it as a travel charger.
Touch screen of this HTRC is great. Nice review as always. To the point with no fluff.
I love that charger, it's the one I use everyday at the track. 1 battery it can do 150W, which is plenty for up to 6S at 5.5A or so. 2 batteries will split 75W/75W, which is enough for 3S at about 5-6A.
Thanks for that info.It's 11-18V only input on DC.
Sorry I made a mistake, the watts are:
DC: 120/120
AC: 75/75, or up to 100/50 split.
So for 6S, not very good on AC, and decent on DC.
Are you looking to charge above 1C @ 6S?
FWIW, the sky rc D400 2x200w/2x20A AC/DC is on sale at rcjuice.com this week.
$160: https://www.rcjuice.com/sale-112/sk...ultimate-ac-dc-dual-lipo-battery-charger.html
I had a question about this charger when i do a storage charge i set the amps at 5.2 (2s 5200 mah battery) should i be setting lower? I hit my storage charge 3.8 volts but it keeps charging. Should i set a limit in the settings because even though it hits the volts of 3.8 per cell it keeps charging up to the capacity. Am i good to stop once the cells show 3.8 or do i let it go? Am i suppose to manually stop it or should it beep and stop...like it does when i do a balance charge? Sorry if this doesn't make sense or i am not explaining myself clearly. I am new to Lipos.I love that charger, it's the one I use everyday at the track. 1 battery it can do 150W, which is plenty for up to 6S at 5.5A or so. 2 batteries will split 75W/75W, which is enough for 3S at about 5-6A.
Storage charge should stop at 3.8-3.83 on it's own. Are you sure your in storage mode?I had a question about this charger when i do a storage charge i set the amps at 5.2 (2s 5200 mah battery) should i be setting lower? I hit my storage charge 3.8 volts but it keeps charging. Should i set a limit in the settings because even though it hits the volts of 3.8 per cell it keeps charging up to the capacity. Am i good to stop once the cells show 3.8 or do i let it go? Am i suppose to manually stop it or should it beep and stop...like it does when i do a balance charge? Sorry if this doesn't make sense or i am not explaining myself clearly. I am new to Lipos.
Nice PSU ! How much was it?My new set up
Man that power supply looks slick. I like it a lot!My new set up
I got the plus. Don't charge in the field. Wanted something for home without a dedicated power supply. If I need a PS down the road, I'll get one.View attachment 40788
