- Gimli Manitoba
- Kraton 8S
- Kraton 6s
- Kraton EXB
- Outcast 8s
- Outcast 6s
- Vorteks
Anything that you don't like about it?I do. Great charger!
Still "monitored"?Is this thread still monitored?
Looking for a LiPo charger that could (ideally) charge 2 batteries at the same time. Only have 2S and 3S batteries, but I suppose the ability to go up to 6S might be nice.
I already own 1 Dynamite Prophet Sport Plus, so I'm curious if I should just get another one, or get a bigger charger.
Doable if you always run them at the same time so that they are at the same voltage. Not doable if your packs differ much in voltage levels.I'm looking for a good charger or good set up to charge my lipo batteries. They are Ovonic 3s 50c 5200 mah 11.1v. I started looking at a dual charger to start with but now I'm thinking can I get a parallel board and charge them all at once? Thanks
Getting a dual charger with relatively high capacity kind of gives you the option to do both. The skyrc 2x200W/2x20A will let you charge 4 3S packs (2 in parallel on each port) pretty easily. Or if you have the packs voltages not in sync, you can still charge 2 normally.
https://www.amazon.com/SKYRC-D400-Ultimate-Battery-Charger/dp/B075G1F8M8
This one isn't bad on AC and puts out more watts on DC, also dual:
https://www.amazon.com/HOTA-Balance-Powerful-Discharger-100-240V/dp/B07Q4SJPHY
Guessing the T240 is a newer version of that, doesn't appear to be much more $80 vs $76 on amazon.Anyone used one of these?
HTRC C240 DUO AC 150W DC 240W Dual Channel 10A Charger
I know its a cheap one but was trying to get one for about $100 ($68US) with storage charge and dual output. For lipo up to 4s.
https://www.amazon.com/HTRC-Charger-Discharger-Balance-Battery/dp/B07P863S9D
I have a different HTRC charger and it does ok, but the push buttons kind of freaked out on me so now I only use it in automode at 12A and don't try changing anything. The +/- buttons get stuck and it just goes and goes, so I don't press them anymore. It defaulted back to "12A auto" when I turn it on now, so I don't mess with the buttons other than to start/stop charging. That's the reason I mentioned the touch screen one as the buttons may be less likely to freak out on you like mine.
Mine is a metal case with bubble surface type buttons:
https://www.amazon.com/HTRC-Twin-Channel-Multi-Charger-Balance-Discharger/dp/B075F49BFD
It also does not like it at all if you plug a pack in before powering it up. The one I have doesn't have a power switch. If it's plugged in, it's on. My bashing buddy plugged his pack in before plugging the DC power in (I only use it as a field charger) and it took a bunch of powering up/pushing buttons to get it to break out of a weird OS boot screen on one channel.
Page 11 of the instructions says it does:Thanks for your feedback.
Does anyone know if the Venom Pro Duo 80W X2 Dual has a storage charge mode? I can't see any mention of it in the specs.
https://system.na3.netsuite.com/cor...774&c=1327152&h=81437dfeec91d3d99487&_xt=.pdf
Yeah, it just isn't very high amperage or wattage. So not for those that are in more of a hurry.
7A/80W x 2 is on the low side. But that's enough to charge up a couple 3S 5000mah packs at a bit more than 1C (5A/55.5W). Will even do a 4S 5000mah at 1C (5A/74W), but just barely.
