If your serious about the hobby and have plans on trying different RC. I would invest on a good charger setup. https://www.progressiverc.com/collections/signature-series
Could parallel charge fifty FPV 6s batteries and still not pull 2000 watts.If your serious about the hobby and have plans on trying different RC. I would invest on a good charger setup. https://www.progressiverc.com/collections/signature-series
Can you even pull 2000w out of a standard wall outlet?Could parallel charge fifty FPV 6s batteries and still not pull 2000 watts.
Impressive
it can but you are at the limit of 15amp breaker. On a 20 amp plug it can no problem but 15 amp is pushing it. I wouldn't run it for more than an hour the wire in the wall will get warm. And only the charger can run on that breaker, if anything else is daisy chained off that plug or breaker it will pop when the charger hits 2000wCan you even pull 2000w out of a standard wall outlet?
Sure, with a 20amp circuit.Can you even pull 2000w out of a standard wall outlet?
You should have gone with at least a 600w psu not 500w. Even if that psu is 80+ certified it will only put out about 400w max. Or just make sure you don't exceed 400w.
Nah he's good. That PSU is rated for 24V at 21A output, 504W.You should have gone with at least a 600w psu not 500w. Even if that psu is 80+ certified it will only put out about 400w max. Or just make sure you don't exceed 400w.
Power supplies also lose some of the power they supply as heat, a measure called efficiency. An 80 percent efficiency, meaning that 80 percent of the rated wattage is provided as power and 20 percent is lost as heat, is considered good. Some power supplies will have an 80-Plus certification logo, indicating they are at least 80 percent efficient. 80% of 500w is 400w.Nah he's good. That PSU is rated for 24V at 21A output, 504W.
Correct, but you've got the calculation wrong. The efficiency doesn't reduce the output power, but rather increases the input power. In this case, the PSU is rated to provide 21A at 24V, for a total of 504W. Assuming the PSU is 80% efficient, that would mean the PSU will pull 630W of power from the wall.Power supplies also lose some of the power they supply as heat, a measure called efficiency. An 80 percent efficiency, meaning that 80 percent of the rated wattage is provided as power and 20 percent is lost as heat, is considered good. Some power supplies will have an 80-Plus certification logo, indicating they are at least 80 percent efficient. 80% of 500w is 400w.
I've never seen one advertise input power w/o advertising output. How odd. Gotta love marketing. LOLIt depends on the Vendor. Typically the advertised rating should be the Output capacity. 500W = 500W useable.
Some advertise the input power in order to not overload the circuits.
Basically down to advertising. Look for rated output value. 500W output is roughly 600W input (pending efficiency)
I remember back in the day the cheap Chinese pc power supplies did this, that is probably where I was getting confused. They would list something like 600w but the actual power output would be closer to like 500w.I've never seen one advertise input power w/o advertising output. How odd. Gotta love marketing. LOL
yeah I remember something about that. IIRC those were also fire hazards. LOLI remember back in the day the cheap Chinese pc power supplies did this, that is probably where I was getting confused. They would list something like 600w but the actual power output would be closer to like 480w.
I still have one of those Chinese units around here someplace I think.yeah I remember something about that. IIRC those were also fire hazards. LOL
I had something akin to those Chinese units a while ago. Once I figured out what the label meant I got rid of it. Nope!I still have one of those Chinese units around here someplace I think.
Even though these guys above can't decide on true power output I know you've just got a sweet setup
I just hope for your ears sake that your PSU is quieter than mine. I've got a 24V 1000W PSU from MeanWell, and even idle it sounds like a jet engine.Tired of taking hours to prep for speed runs. Hoping to charge my 9500mah 4S packs at >1C. Right now I’m limited to about 6.5A with my current charger.
As far as PSU choices, if I end up needing larger supplies, I will send these back and upgrade. Meanwell is a decent brand.
It will be in the garage next to my air compressor and server rack which are both already annoyingly loud. Will fit right in.I just hope for your ears sake that your PSU is quieter than mine. I've got a 24V 1000W PSU from MeanWell, and even idle it sounds like a jet engine.
