vpr5793
- Mojave
Nice!It will be in the garage next to my air compressor and server rack which are both already annoyingly loud. Will fit right in.
That's the way the dells are when at idle. The fans run at 100% until there's a 3-4 amp load on the PSU, then they calm down. Sucks when discharging and for the last 5-10 minutes of balance charging. I sold mine off and built my own out of some HP PSU's. Much quieter, even under 30A load.I just hope for your ears sake that your PSU is quieter than mine. I've got a 24V 1000W PSU from MeanWell, and even idle it sounds like a jet engine.
IIRC Meanwell is an actual OEM for power supplies, a lot of companies rebrand their units.Tired of taking hours to prep for speed runs. Hoping to charge my 9500mah 4S packs at >1C. Right now I’m limited to about 6.5A with my current charger.
As far as PSU choices, if I end up needing larger supplies, I will send these back and upgrade. Meanwell is a decent brand.
Should have got a least a 1k watt psu or 1500.
I got two 500W meanwellsShould have got a least a 1k watt psu or 1500.
https://www.ebay.com/itm/Mean-Well-RSP-1500-24-Switching-24V-63A-Power-Supply-Unit/154316875263?ssPageName=STRK:MEBIDX:IT&_trksid=p2060353.m1438.l2649
I was trying to decide between 10awg and 12awg. Looks like xt60 takes up to 12awg. I think I have some silicone high strand 12awg left over from my amp install.500W 20A
I'd do 12 AWG. You can always go larger.
Steel 50cal ammo cansHow do you guys protect your batteries? I have (3) 3s batteries and (1) 6s. I have seen online that Lipo safe bags are rubbish. Looking for something not too ugly. I have seen people use cinder blocks or whatever. Looking to put this in the garage we will be renovating in the summer. TIA
Found one on Amazon for 20USD. Looks good! Thanks!Steel 50cal ammo cans
I kept a large pot from our old pots and pans when I got my wife new ones. If it can take the stove and oven for extended time it should be able to handle lipos. Way better than a ”safe bag”, most of those are a total jokeHow do you guys protect your batteries? I have (3) 3s batteries and (1) 6s. I have seen online that Lipo safe bags are rubbish. Looking for something not too ugly. I have seen people use cinder blocks or whatever. Looking to put this in the garage we will be renovating in the summer. TIA
Man these chargers are a game changer. Went from over an hour to charge 4S packs to 16mins
My SkyRC B6 Duo Nano can do up to 10A in single channel mode or about 6.6A running dual channel. These IDST chargers push the full 20A without blinking.
My Turnigy Graphene battery can go 5C according to the label. Charges from dead empty to full in less than 15 minutes LOL. High-Power chargers are awesome. With 3/4 batteries you can literally go all day and give the "All I have to do is fuel up" Nitro guys a run for their money.Man these chargers are a game changer. Went from over an hour to charge 4S packs to 16mins
