highrisedrifter
Thanks for the reply. I was just reading the 'what charger do I need' thread on here and it mentioned future-proofing, so I thought that might be a good idea.Its 4 channel meaning you can do 4 packs at once. Dc only though which is understandable since it has a high output. You will need a power supply to run it. Or use a deep cycle marine battery if your at the track. Do you need the 4 channel vs 2 channel?
Right now I only need two charging ports and a charger that is at least 150w per channel for the 6s lipos.
