slick2500
Anything will break if you drive it wrong enough.
Community Leader
ArrmaForum Fan
- Rapid City, SD
- Fireteam
- Kraton 6s
- Kraton EXB
- Outcast 6s
- Senton 3s
- Typhon 3s
Yeah trying to find that kind of thing on Google was not getting me much if anything close to what I was looking for. The suggested load on the first charger is 80% of the 800w if I am reading that correctly so the second one might be the better option.Ugh, my first iCharger was the same way, 18V max. My big charger tops out at 30V in, which ruled out high-power 36V solutions. I got a surplus 1500W 24V industrial power supply (well over $1,000 new) for $100 on eBay, and adjusted it up to 28V. It's meant to run 24/7, and is far better quality than any colorfully-anodized supply sold for RC use.
Looking for 18V options for you, this is $75, 18V, 800W: https://www.aliexpress.com/item/4000184162521.html
Would be nice if the voltage was adjustable, though, to let you go to 17V or whatever you felt comfortable with. I guess if the 18V came in at actually 18.5V or so, I guess you could add a suitably-large diode inline, to drop the voltage a bit. But that's a pain.
15V ($85) and 18V ($75) 1000W options here: https://www.aliexpress.com/item/32789770858.html
I find Google lets me down a bit when searching for this sort of thing, since I can't figure out a way to search for something like >750W. So I search for 800W, then 900W, etc, hoping to get lucky. I spent quite a while scouring eBay before finding mine, searching different ways, and hoping something good would turn up. It eventually did.
Note that chargers are not 100% efficient. If you want 800W output, I would plan on supplying >800W. Barring better info, I'd assume maybe 90% efficient, which would require about 900W in.
Stupid question with that, how do I add a cord to plug it into the wall, it only has 2 prongs.
