Recommend me an ESC for Kraton 4s
olds97_lss
Bash Break Repeat!
Dekalb, IL
  1. Outcast 6s
I would lean towards the max8 as well, or one of it's cheaper HW cousins (WP-8BL150).
One thing that bugs me about castle (probably more than it should) is that you have to unplug it from the receiver to adjust the programming or download the logs. It's far more convenient to unplug the fan, plug a little box in, adjust whatever, plug the fan back in and go. Vs cracking open the receiver box, dealing with all the fiddly wires and balloon if you have one over the receiver for waterproofing, then have to put it all back and hope you like the adjustment. Sure, you can buy the bluetooth thing or the adapter thing, but why? Why can't I just use the fan port like the hobbywing?
I know @bicketybam likes the mamba X in his smaller trucks. Although, I don't know why you would get that instead of the MMX, other than it's a bit smaller in size and the MMX is a few $ more with higher current handling, similar capabilities for programming and same BEC. I run the mmx/2200kv sensored in my savage flux hp on 6S and it does ok. Runs a bit warm, but I'm still trying to figure out gearing. When I had it on 4S, it was fine, gearing it down for 6S is necessary as it's just a handful to drive that thing above 50mph. lol! And it causes things to run warm.
slick2500
Community Leader
ArrmaForum Fan
Solutions
6
Rapid City, SD
  1. Outcast 6s
  2. Senton 3s
  3. Typhon 3s
Just curious why you would go with mmx? I haven’t really researched that one.
I have both the Max8 and the MM2 the MM2 for me it just performs better and the power delivery just feels a lot smoother than the Max8 does.
